Hi Guys I'm planning go build a pc for myself but I don't know if my build is ok.
Will my build be good in my current monitor?
Its 1440p and has 144hz. will I achieve even 80 fps or more when playing AAA games?
Case new Phanteks Enthoo Evolv ATX Glass Black with Tempered Glass
Motherboard new mb am4: Asus Prime X370 Pro
Video Card new GTX 1070 Strix
Ram new g.Skill tridentz rgb 16gb or anything that can be suggested that will also be good in my build.
Cooling system new NXZT Kraken x62 ** I like the looks that's why xD
Power Supply new psu EVGA SuperNova 650G2 750watts 80plus gold full modular
Processor new Ryzen 5 1600 or 1600x?
Monitor current monitor Acer Predator XB271HU
Thank you!!!!!!
https://linustechtips.com/topic/778665-new-pc-build-help/
Location?
Edit: Are you doing a RGB build?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820098
Nah, this is what I recommend, budget (not really) RGB Ryzen build:
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($312.05 @ Amazon)
Motherboard: ASRock - Fatal1ty AB350 Gaming K4 ATX AM4 Motherboard  ($104.99 @ SuperBiiz)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($144.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($84.99 @ Jet)
Storage: Hitachi - Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive  ($56.50 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1070 8GB G1 Gaming Video Card  ($403.98 @ NCIX US)
Case: Corsair - Crystal 460X RGB ATX Mid Tower Case  ($139.99 @ B&H)
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ SuperBiiz)
Total: $1327.48
Generated by PCPartPicker 2017-05-12 07:36 EDT-0400/
The stock cooler of the 1700 also looks good. Has RGB!
Desktop specs:
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820112
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor  ($328.79 @ SuperBiiz)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($98.99 @ Amazon)
Motherboard: MSI - Z270-A PRO ATX LGA1151 Motherboard  ($109.89 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory  ($113.88 @ OutletPC)
Storage: ADATA - Ultimate SU800 256GB 2.5" Solid State Drive  ($94.99 @ NCIX US)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($69.89 @ OutletPC)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($340.12 @ Amazon)
Case: NZXT - S340 Elite (Black) ATX Mid Tower Case  ($89.99 @ SuperBiiz)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Amazon)
Total: $1296.53
Generated by PCPartPicker 2017-05-12 07:43 EDT-0400
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820123
Since ZM Fong already made a RGB one I'm gonna make a Non RGB One (mostly same parts).
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($311.97 @ Amazon)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($84.49 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($129.89 @ OutletPC)
Video Card: MSI - GeForce GTX 1070 8GB Video Card  ($394.99 @ Newegg)
Case: Phanteks - Enthoo Evolv ATX Glass ATX Mid Tower Case  ($174.99 @ NCIX US)
Total: $1331.20
Generated by PCPartPicker 2017-05-12 08:19 EDT-0400
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820193
49 minutes ago, ZM Fong said:
Location?
Total: $1327.48
Sorry just replied now. I'm from the Philippines.
 I want to build a semi RGB build. I can replace the RAM memory with a cheaper one.
btw I have a 1440p monitor with 144hz.
If I will go with the Ryzen 5 1600 will it work okay like I will still get around even 80fps in AAA games? or it will be having a hard time with it?
Your list looks good :)
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820219
Will be okay, but the stock cooler doesn't have RGB lighting
Thanks. I like to make part lists to others.
Keep in mind that you will not be able to get all the exact parts in Philippines (for instance, you can't get the SK Hynix SSD here in SEA region) so if you have any questions, feel free to ask me.
Desktop specs:
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820230
20 minutes ago, EasonIDontKnowAnything said:
Non RGB One
Comes with RGB stock cooler
Desktop specs:
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820232
4 minutes ago, EasonIDontKnowAnything said:
well uh that's an exception plus no way I'd switch it out for another one, it's not only great but it looks cool
You can choose R5 1600
Desktop specs:
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820244
R5 1600 is a good alternative to R7 1700
Desktop specs:
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820260
I'm okay if there is no rgb stock cooler. Will the kraken x62 good for that one? I like the structure of that cooler but I'm not sure if its compatible. and for the Memory stick do you know other memory that can also be used? with or without rgb is fine.
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820416
X62 is pretty but it's also expensive.
Any RAM will work fine but beware of compatibility issue. So far G.Skill FlareX is the only 100% compatible RAM with Ryzen. Other RAM may work or may not work.
Desktop specs:
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820427
Yeah it's beautiful but expensive.
but the g.skill trident z rgb will work fine right?
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820477
I'm not sure about Ryzen RAM compatibility. I can't ensure 100% compatible. If you're worried about incompatibility, get 2666MHz RAM.
Pros needed for help. @DocSwag
Desktop specs:
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820702
Yup it'll work fine, really any ddr4 ram will work with ryzen, it's just up to at what frequencies it will work.
Optimally you'd be getting 3000 mhz/3200 mhz cl14 ram or higher frequency ram, as those overclock the best on ryzen, but those also are pretty expensive.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9820832
So If i will get the trident z rgb 16gb 3000mhz it will work fine with the ryzen?
I see thank you!
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9821011
I see thank you!
Yup, anything works, it's more that some kits overclock better than others ;)
I can't guarantee that that kit will run at 3000 MHz, if it's CL14 it'll have a higher chance of being able to. But it'll definitely work.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9821079
I see. More important it will work by default. Thank you guys!!!
https://linustechtips.com/topic/778665-new-pc-build-help/#findComment-9821523
