4+2+2? You have 8GB of RAM?
RAM speeds shouldn't effect gaming too much. I wouldn't bother upgrading your ram and instead aim that money towards a better GPU or if you have a crappy one a better CPU. Those will have a much bigger effect to your gaming performance.
https://linustechtips.com/topic/778141-ram-speed/#findComment-9814140
Would having a 4gb dimm and 2x2gb dimms effect performance at all since the 4gb one wont be in dual channel?
Zalman Z9 Plus - GTX 660 TI - i5 2500k @ 4ghz - MSI 1155 Intel P67 - Corsair CMPSU-750HX - 16GB G.Skill Ripjaw 1600mhz 9-9-9-24 - Seagate ST3500413AS 500GB - Seagate ST2000DL003 2TB Backup Storage -  Old CBA to change it.
https://linustechtips.com/topic/778141-ram-speed/#findComment-9814170
Nope, no noticeable affect. Maybe two or three more points in a synthetic benchmark, bot no real FPS difference in real world gaming.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/778141-ram-speed/#findComment-9814281
6 minutes ago, Strike105X said:
What's your pc specs?
I5-2300 2.8Ghz
intel h67
asus gtx 1050ti
But im having problems in gta-v
world sometimes takes too much to load stuttering even when fps is good
a guy said i need a better ram i got a 4gb 1333 before i get a 2*2gb 1066
But i got some bsods and freezes
https://linustechtips.com/topic/778141-ram-speed/#findComment-9814322
4 minutes ago, Mohammad al-sharif said:
I5-2300 2.8Ghz
intel h67
asus gtx 1050ti
Upgrade to an i7 2600, and get more RAM, not faster RAM. 8 threads and 16Gb RAM will make a world of difference.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/778141-ram-speed/#findComment-9814327
Someone might be able to recommend a cheaper equivalent Xeon, but IDK that generation of Xeon.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/778141-ram-speed/#findComment-9814330
Just now, Mohammad al-sharif said:
but my cpu usage was mostly <80%
If you had enough RAM your CPU would be at 100%. You need more CPU and more RAM. Your friend was partially right about "better" RAM.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/778141-ram-speed/#findComment-9814333
8Gb RAM is just not enough to be playable on GTAV, and it will use six of my physical core at least.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/778141-ram-speed/#findComment-9814335
Thanks
So i should aim for more ram not faster ram
I cant change any of the specs right now actually
Yes, more RAM, not faster. A higher core count CPU would really help in GTAV as well as some other games, not all games will benefit though.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/778141-ram-speed/#findComment-9814343
2 hours ago, Strike105X said:
Personally i would go for a i7 2600 like its been said by asand1 and look up supported ram for your config, sell of what you got and go for a 4x4 dual channel 1333mhz ram kit.
I cant do that right now
but looking at ram would 1333 give me any advantage in gaming ?
https://linustechtips.com/topic/778141-ram-speed/#findComment-9814640
16 gb would, yes.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/778141-ram-speed/#findComment-9814776
