This really pisses me off. Sometimes fps drops low all the sudden (especially when going outside) & from 60 it drops to 30 & game lags a little. To restore normal fps it needs to quite the game & launch it again.
Any tips to solve this?
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/77792-skyrim-fps-drop/
Just wondering, do you have VSync turned on?
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068085
New GPU? The 560 is getting old.
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068086
Is VSync on? Mod list? Background programs? Does it only happen in certain spots at the same time or does it happen at random times?
4790k @ 4.5Ghz 1.180v NZXT Kraken X31 | MSI Z97 Krait | Kingston Hyper X Fury 32GB 1866Mhz, 2 DIMMs white and 2 black | GTX 980 Ti - G1 Gaming | GTX 680 - Reference | SilverStone ST75F-P | Phanteks Enthoo Pro
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068122
yes
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068240
But it handles it on ultra with 60fps if not count that sudden drops which is cause by game itself.
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068242
any mods?
Yes, but it had fps drops before mods too
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068245
VRAM limitation, intensive mods?
nope
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068246
Yep, v sync's on, mods doesn't cause it as, it happened before them too. No background programs. It seems, it only happens when entering in new location (sometimes).
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068253
yes
That might be your problem. VSync does some crazy stuff.
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068258
Okay, I'll turn it off & let's see if it helps.
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068270
Hmm, I can't find the vsync option. This is all I have in options:
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068302
I don't play Elder Scrolls games but I'm sure it is the same process as Fallout. You have to go into the Skyrim.ini and change 'iPresentInterval=1' to 0.
After you do that you should probably turn adaptive Vsync on in the Nvidia control centre.
https://linustechtips.com/topic/77792-skyrim-fps-drop/#findComment-1068358
