Hello, Im running Windows 10 and my computer will not boot at all unless i clear the CMOS by pushing the button in the back. After doing that the computer boots up and will run fine. However if i attempt to shut down then turn it back on it will not boot unless i hit the clear CMOS button. It also wont turn on after i hit restart in windows. Not sure what the problem is or how to fix it. Plz help?
Rig:
i7 5820k
32 gb Gskill ram
Asrock killer x99 motherboard
samsung 850 evo 1tb ssd
gtx 980ti
all with custom watercooling throughout.
Edited by Wingley_Lloyd
added rig info
https://linustechtips.com/topic/777861-trouble-turning-on-system/
Rig:
i7 5820k
32 gb Gskill ram
gtx 980ti
do you have a software that loads up a overclock profile at boot?
