Hello
So I gotm y Samson C01U for liek half an year now, there wasnt nay problems I even got recorden a few videos recently and sound isj ust okay. But today while testign the recording I notice that when I speak there is that electricity sound in the background, its hard to explain but hope someone  knwo what I mean and can tell me something about it.
https://linustechtips.com/topic/777822-my-microphone-sound-problem/
4 minutes ago, Belzebuth said:
Multi-socket ? I don't know the english name :/ But what I mean is sometimes the noise may come from something plugged recently to a power outlet near your computer
Hmm nope, I tried to chang usb socket even tryed to place it in the from sockets, same thing that electrical noise, I tryed to plug in my old trust starzz mic into the from mic socket and it works perfeclty I mean no electrical sounds. So what could be that after night mic (Samson) start giving that electricaly sounds
11 minutes ago, Belzebuth said:
The C01 is a condenser mic, much more sensitive than your old Trust.
Can we have maybe a litle sound file before the issue and one after ?
Man u helped alot, jsut to be sure I recorded sound only with bandicam isntead of Nvidia Experience software for ecording which I use to record videos, and omg there is no sound problems at all I attach the file. I remember how today before launching nvidia experience got an update and after that the issue is came up. Thansk alot u helpedm e to figure it out. Now only thing is I need to find the best recording optiosn for bandicam.
bandicam 2017-05-10 16-23-28-928.mp4.wav
2 minutes ago, Belzebuth said:
Glad you find a way to make it work !
Try to lower you gain a bit to avoid the white noise then use a software noise gate or noise réduction engine. But I'm not a Bandicam expert can't help much for that :/
As far as I checkedm y youtube videos there is not that much background noise so I think will stick with that quality for now, I jsut started so itsn ot that big of a deal.
Check it out mby u got some suggestions abotu quality?
https://www.youtube.com/user/HUNLIGHTtm
It's sound quite good on youtube, not to much noisy. Condenser mic are hard to use in home environnent, because they can pickup every litle noise in the room, so if you plan to upgrade in the futur, you might start thinking of a good dynamic mic, such as shure sm57, or sm7 (very expensive), with an XLR interface. But for now your video sound good.
Enjoy
