PC BUILD COMPONENTS for 2000$-2400$
Go to solution Solved by tom_w141,
Under $5500... So literally anything
That's enough budget for 5 mid spec PCs or 2 top end PCs
This one is badass.  Especially the RAID0 SSD.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
Guess it depends how you're getting to and from college, if you have your own car (you should if spending $8k on pc gaming) then just build an matx build and don't bother with the laptop, they loose money so fast with no upgrade route
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
