4 minutes ago, Linksys120n said:
you know I had to google the board to make sure you didn't just put an i5 in a mobo made for ryzen... You didn't its lga 2011 or something like that...
anyway what cooler are you using?
Lga 1151 but I fixed it I accidentally had the back plate on backwards it was flipped to amd and I didn't notice
Top side brackets look like they could be backwards too. Maybe check those before stuffing all inside case. If you already have went for it, lets hope you don't damage anything.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
