So i bought an XLR Mic and the Behringer 302USB Xenyx 5 and i Cant get it to work with my MIC .
Now I never used anything like this so i simply connected it with the power thing to the wall till i shortly relise i also have to connect it to my laptop
So i used the USB to connect it straight to my laptop and its powered on but the the mic and the headset are not working..
It has INPUT L AND R line but i have no idea how and what to do !
If I shouldn't have bought this because It doesn't work with Pc's please tell me so i can at least try and return it :P
Edit* : It's working now but It's giving alot of HISSS noises Any ideads how to deal with them ?
https://linustechtips.com/topic/777408-help-with-audio-interface/
did you select the proper playback device in the windows audio settings?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
6 hours ago, NewBieDavid said:
uhmmm which one exactly ? :D
You should have something called like 'Behringer Line 1/2' for example. Mine says 'Input 1/2' (Komplete Audio 6) on my portable setup.
You could also try another sound card on another pc, if available.
Is the gain of the pre-amp turned up?
Does the mic cable function properly?
Yes everything is normal.
I ended up sending it back
now I'm using the MIC straight to my laptop without phantom power which i find weird because people told me i need a Psu
It still has backround noise but considering I have no audio interface I'm fine with it .
Does a cheap 50 bucks Audio interface with phantom power help ?
if so can you recommend one ?
