Hello guys, I'm new here. I really need some help. So few days back i upgraded my pc. here's my pc spec's:-
1- Ryzen 5 1600
2- Msi B350m Mortar Gaming motherboard
3- G.Skill DDR4 3000mhz Memory
4- Nvidia gtx 1060 Asus Strix Edition 6gb.
Now the problem is, With default settings My DDR4 memory Runs at 2133mhz but when i try to overclock it at 3000 or 2600mhz or anything other than default value my pc won't boot and after a while it shows an error message that it failed to boot and it went back to last known good configuration. I'm not good with Voltage stuff so i didn't touch that thing. Any kinda help would be great. Thanks.
https://linustechtips.com/topic/777403-need-help/
Your RAM probably not compatible with your mobo IMO
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/777403-need-help/#findComment-9805220
Did you adjust timings /voltage in line with your memory kit specifications?
Or are you just using XMP?
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/777403-need-help/#findComment-9805247
