Hello.
For my new build I decided to pay attention to how silent the components are. I want to have a silent system when I'm working on a paper or coding. That's why I want to have a semi-passive card. I'm fine with it being louder during load but it shouldn't sound like a jet engine. xD My case will be the Define S. I hope that the airflow privided by the case fans will be enough to keep the GPU fans off.
I just want to get some feedback on cheaper semi-passive aftermarket coolers (RX 470/480/GTX 1060). I know that the ASUS ROG Strix or MSI Gaming X card would be quiet but I'm searching for something a bit cheaper.
It would be awesome if you can share your experience with you card.
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/776260-gpu-cooler-advice/
almost all aftermarket cards from good brands like MSI, Asus, Evga, Sapphire will have 0 db mode that sets fans off below 60 Degree Celsius in their flagship or below such as MSI GAMING Cards.
and please do not buy 470/480/1060 cards the RX 5 Series just released and they will be cheaper with similar better performances and temps.
https://linustechtips.com/topic/776260-gpu-cooler-advice/#findComment-9791440
I know that the RX 500 Series was relieased. I don't care about the difference compared to the RX 400 Series, I will get the cheaper one. But the prices atm are a bit weird where I live.
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/776260-gpu-cooler-advice/#findComment-9791458
