They are okay but there are better ones.
My personal recommendation are the Silverstone AP121 or AP123
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/77625-h220-fans/#findComment-1065313
Are the stock fans on the H220 decent or should i go aftermarket?  Also please don't suggest me noctuas, as i will only ever use them if i have a case without a window (no offence noctua fans ;) )
No offence for the noctua fans or no offence to the noctua fans fans? lol
As said Silverstone AP's are good or maybe gentle typhoons?
But first see if the swiftech fans are any good, to me they seem to be one of the best fans delivered with AIO coolers (don't have a h220 tho)
current system:  i5 2500k @4.5ghz cooled by antec 620 - asrock z77 extreme 4 - 8gb corsair RAM - MSI Twin Frorz 7950 in crossfire - XFX 850w  - Fractal design R4 - samsung 840 120gb ssd - 500gb wd blue hdd - 1440p korean qnix monitor (love it!)
https://linustechtips.com/topic/77625-h220-fans/#findComment-1065342
The helix fans are excellent. The noctuas will get you a couple Celsius Better
AMD FX-8350 @ 4.7Ghz when gaming | MSI 990FXA-GD80 v2 | Swiftech H220 | Sapphire Radeon HD 7950  +  XFX Radeon 7950 | 8 Gigs of Crucial Ballistix Tracers | 140 GB Raptor X | 1 TB WD Blue | 250 GB Samsung Pro SSD | 120 GB Samsung SSD | 750 Watt Antec HCG PSU | Corsair C70 Mil Green
https://linustechtips.com/topic/77625-h220-fans/#findComment-1068959
https://www.youtube.com/watch?v=qWQGmX994fU&list=PL47F36BFAE688108B
i found this video and purchased the H220 and Noctua NF-F12 fans. i mounted the fans in a pull config like they did and mounted the rad and fans in the top of my case. my case has a window, but because the fans are in the very top space possible with the rad beneath them, i can't even see the fans. plus, even if i look on top of my case where the fans are mounted to the mesh, you can't really see them that much (i understand your point: Noctua fans look hideous. i agree).
anyways, check out the video too, they've got some good suggestions and statistics.
Windows 10 | AMD FX-8350 @4.6GHz | BeQuiet! Dark Rock Pro 3 | ASUS M5A99X EVO R2.0 | 16Gb G.Skill DDR3 1866 | MSI Nvidia GeForce GTX 980 4Gb | Samsung 840 EVO 250Gb | Corsair HX750 | NZXT Source 530 case | Logitech G710+ keyboard | Logitech G500s mouse | Saitek X52 Joystick and Throttle | Saitek ProFlight Rudder Pedals | TrackIR
https://linustechtips.com/topic/77625-h220-fans/#findComment-1094499
Are the stock fans on the H220 decent or should i go aftermarket?  Also please don't suggest me noctuas, as i will only ever use them if i have a case without a window (no offence noctua fans)
the Swiftech Helix 120 PWM is a clone of the great Sythe GT/AP-15 (1850) fans. not as expensive,
but not exactly the same caliber. since the GT-15 is not PWM, this can easily be an answer to fan
control without typical under-volting issues that the GT-15 has (click/grind). but there different fans
for different tastes and noise level performance, too. to split the differences the SF Helix 120 PWM
is pretty down the line of cost vs. performance.
https://linustechtips.com/topic/77625-h220-fans/#findComment-1094534
