Hi there,
I am i the process of setting up my speakers to my pc. I also have a pair of headphones plugged into my pc.
The problem here is that i cannot play sound though the speakers, only my headphones, had my hifi friend come over to check if something was wrong with the speaker or amp or somethong, but it works just fine on my phone, so, i assume the problem lies in windows, the question is, what the hell do i do?
Kind regards
https://linustechtips.com/topic/775779-win-10-speaker-problem/
Windows can only play to one output at a time unfortunately.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/775779-win-10-speaker-problem/#findComment-9786087
If you want sound through both at the same time, get a 3.5mm splitter cable. Probs about £1.
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
https://linustechtips.com/topic/775779-win-10-speaker-problem/#findComment-9786092
Wrong
6 minutes ago, pieguye said:
Hi there,
Kind regards
Right on the realtek section click on the cog in the top corner, the top two tick options are both about muting the rear when front port is plugged in and playing separate audio.
Its annoying to set up and get the audio you want playing out the correct option but a good fiddle will solve it.
https://linustechtips.com/topic/775779-win-10-speaker-problem/#findComment-9786106
16 minutes ago, Ahoy Hoy said:
Wrong
How is it wrong? Are you saying it wouldn't work? It's what I do.
https://linustechtips.com/topic/775779-win-10-speaker-problem/#findComment-9786177
Your wrong because you can play two separate audio tracks from one computer to two separate devices. I give you it is the biggest pain in the arse to get to work, but completely possible to do.
https://linustechtips.com/topic/775779-win-10-speaker-problem/#findComment-9787044
But I didn't say you couldn't did I. I offered up a method of doing it, a method that works. Not once did I say it's the only way of doing it. Plus your method varies depending on the internal sound driver. My method works 100% of the time.
https://linustechtips.com/topic/775779-win-10-speaker-problem/#findComment-9787121
