Quadro M2000M issues
Solved by MildlyUpsetMax,
31 minutes ago, Electronics Wizardy said:why do you have geforce expenence on there?
What is gpu usage like?
What gpu is the program running on?
Try using the driver from lenovo.
For whatever reason, updating my BIOS via the Lenovo auto driver updater did the trick. Thanks for the tip mate, you're a GD ledgend.
-MuM
