We need more information. What all does it do? When did it start doing this? Specs?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/775100-cpu-help/#findComment-9777957
3 minutes ago, Eliehlers said:
I checked all of the part the ones you need to know about is i5 7600k and for the motherbroad its a ga-z17oxp-sli motherboard
Is this a new build or upgrade? Or did you do something that caused it to stop working?
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/775100-cpu-help/#findComment-9777985
1 minute ago, Eliehlers said:
IIts a new build my first one fyi so this is why im posting here
Ok. Well the most common mistakes are ram. Which have to be in the second and fourth slot; it looks correct you might just want to reseat them. And also the power button cables. Check the manual to see if the power button is connected in the proper pin.
https://linustechtips.com/topic/775100-cpu-help/#findComment-9778034
This could also help. Keep in mind that this is most likely easily fixable and all you need is patience. Don't rush anything and I'm sure it will turn out fine in the end :)
https://linustechtips.com/topic/775100-cpu-help/#findComment-9778098
If none of the above works you most likely will need to update the bios as sometimes kabylake cpu's don't work out of the box on z170 boards.
Pcpartpicker compatability notice:
  • Some Intel Z170 chipset motherboards may need a BIOS update prior to using Kaby Lake-S CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions.
https://linustechtips.com/topic/775100-cpu-help/#findComment-9778106
1 hour ago, Eliehlers said:
My pc is turning on but wobt boot in bios can anyone give me help please
Wow.. Seriously.. ??
Don't want to be a dick... but if you built it........ with that cable management........ bring it to a PC shop lol
No seriously...
Re-seat RAM maybe ? Like other stated.. this could be a lot of things..
Check RAM and Power to CPU and GPU
https://linustechtips.com/topic/775100-cpu-help/#findComment-9778206
As others have stated it may be the RAM. Also you are using a Kaby Lake CPU on a z170 board so you may need to update the bios with a Sky Lake ship before it will work. That being said, why do you have a stock cooler? Intel doesn't ship them with their higher end chips.
i5 6600k @ 4.4ghz on Hyper 212 Evo
Powercolor RX 480 8Gb Red Devil @1330Mhz
Bottom line:  Don't be a spaz or an 800lb gorilla when installing your expensive CPU, and you won't have any problems. --Phate.exe
https://linustechtips.com/topic/775100-cpu-help/#findComment-9778226
