Hey guys,
I am in the process of buying a Røde NT1-A, the only insecurity for me at the moment is how I am going to mount it to my desk. I will soon have a 27" Triple monitor setup and dont want the Microphone to block my sight on any of the monitors since I am also goning to use it for voicechat while gaming and working. As I said, I am unsure about how to mount it and how much distance there has to be between my mouth for the mic for it to sound best, I also don't know how the microphone should be oriented. I have seen some solutions by other people but neither of them seemed to reflect my purpose of using the microphone. I would also like to have a microphone arm, since this is what seems to be the easiest option to tuck the mic away when I don't need it at the moment.
Do you guys have any idea on how to mount the mic ideally?
Thanks a lot in advance!
"I was once invited to a party over at a friend's house. At 3 am, I found myself in his room with some friends, overclocking his graphics card. This pretty much is me in a nutshell."
(I'm getting invited to a lot more parties since then, by the way)
https://linustechtips.com/topic/774424-microphone-setup-with-multi-monitors/
Most people put them above or off to the side .They shouldnt block your view if you position it correctly,
Image result for pc mic setup
