Hey guys im really not sure how i should b bleeding my loop thought i was doing it right but dont think i am. i added to videos if that helps
Im using  ek cryofuel acid green coolant.
these pictures are before i try to bleed the system
https://youtu.be/eY1DrM1u8mE
https://youtu.be/fi2w9gW7fhU
18290178_10155360354634445_207137973_o.j
18236130_10155360354489445_672988651_o.j
https://linustechtips.com/topic/774239-help-with-bleeding-my-loop/
Try removing that air fitting on the top rad port and seal off the res before turning off the pump.  Seems like it is letting air back into the system between your fillport being open and possibly that allowing air back into the rad.  I haven't used that res but I would want it more full while it is running as it seems kinda close to the bottom
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
Thanks looks like that help. think i had a bad bottel of pre mix i flushed the system again and put another bottle in and looks alot better then before
18261511_10155360599739445_221969697_o.j
