3 minutes ago, KuJoe said:
Can you elaborate on this? What exactly is happening and how are you testing it?
I can't load webpages steam won't connect discord won't connect spotify says I have no internet but my computer shows me as on the network14936791031571250326865.thumb.jpg.784c366efbddc2f9c8a31d8ad09c6ee8.jpg
https://linustechtips.com/topic/774188-internet-help/#findComment-9766802
6 minutes ago, KuJoe said:
Try these steps and reply with the results:
  1. Ping your gateway
  2. Ping google.com
  3. Ping 8.8.8.8
  4. Traceroute to google.com
  5. Traceroute to 8.8.8.8
This will help me determine where your problem is.
I couldn't ping,my default gateway
I couldn't ping googl.com
I got all 100% pinging 8.8.8.8
I don't know how to traveroute
https://linustechtips.com/topic/774188-internet-help/#findComment-9766821
1 minute ago, LegendOfZirkle said:
I'd rather not post my ip but I can't ping my default gateway
This is your internal not external IP.
Sounds like a network card is going bad. Reinstall your drivers and try over Ethernet.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/774188-internet-help/#findComment-9766857
It only shows your local IP addresses. There's nothing we can do with those.
Here's mine:
Windows IP Configuration
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . :
   Link-local IPv6 Address . . . . . : fe80::a0ab:54f0:57b6:5888%12
   IPv4 Address. . . . . . . . . . . : 192.168.1.100
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 192.168.1.1
In the ipconfig results, is a default gateway set? Try pinging the same address from another device and see the results. Try connecting directly to the router with a cable if you can. If it works over hardwire, it's likely an issue with the WiFi's configuration.
https://linustechtips.com/topic/774188-internet-help/#findComment-9766859
Here's mine:
  Reveal hidden contents
I'll do t in a sec after I try reinstalling network drivers
https://linustechtips.com/topic/774188-internet-help/#findComment-9766875
   Media State . . . . . . . . . . . : Media disconnected
Wireless LAN adapter Local Area Connection* 12:
Wireless LAN adapter Wi-Fi:
   Connection-specific DNS Suffix  . : Belkin
   Link-local IPv6 Address . . . . . : fe80::882c:95fd:b7c3:41ec%14
   IPv4 Address. . . . . . . . . . . : 192.168.2.7
   Default Gateway . . . . . . . . . : 192.168.2.1
Ethernet adapter Bluetooth Network Connection:
Tunnel adapter isatap.Belkin:
https://linustechtips.com/topic/774188-internet-help/#findComment-9767124
