Help with unrooting
Go to solution Solved by compupertortoise,
11 minutes ago, huilun02 said:
Try to disable root access (in supersu app, or hide root in Magisk) and then login to Snapchat. Re-enable root after.
If you want more detailed help, I'm going to need to know what phone model and ROM you are using.
You know what xDxD I made it work somehow...
What I did:
So before I started playing with previuously mentioned script, I did a nandroid backup. Because my phone got bricked of script, I just booted in download mode (because I could't get in recovery) then I flashed TWRP via Odin. Restored my system from the backup I made before. I had no supersu in my system for some reason, tried to log into snapchat AND I GOT IN! Then I just downloaded SuperSu zip and flashed it from twrp. Now I have working root (e.g. Adaway works perfectly) and working snapchat!
Thank for trying to help!!
I want to use snapchat, but with root it kinda hard. So tried to unroot using this script and then as the instruction said, I pulled out boot.img from the zip file of the ROM i'm using. I flashed that script zip using TWRP and then flashed boot.img. My phone got stuck in bootloop. I have no idea what I dod wrong
https://linustechtips.com/topic/773904-help-with-unrooting/
1 minute ago, huilun02 said:
You soft bricked your phone
Now you have to unbrick it
The process to do so varies across manufacturers and phone models
And we have no idea what phone it is
Yeah I fixed that, my phone works fine. I'm just wondering how to get snapchat working.
https://linustechtips.com/topic/773904-help-with-unrooting/#findComment-9763705
Download the app hidemyroot
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/773904-help-with-unrooting/#findComment-9763718
I have Samsung S6 edge+ ( SM-G928F) with Pure-Stock ExtraLite ROM. Disabling root acces in supersu app didin't help. I had other room with magisk and the hide feature worked, but as i'm running supersu that doesn't help.
https://linustechtips.com/topic/773904-help-with-unrooting/#findComment-9763727
What I did:
https://linustechtips.com/topic/773904-help-with-unrooting/#findComment-9763742
41 minutes ago, huilun02 said:
You're welcome
Upon further searches it seems that Snapchat app was coded to look for supersu, so even if root was disabled snapchat won't let you in.
With supersu and related files gone Snapchat should then work.
Good that you also use Adaway. Its a must have for all of my phones :P
That just stupid that they did that with Snapchat. Only reason why they should do that if they wanted to prevent people from taking screenshots without OP seeing it, but there is still workarounds wiht unrooted phones.
Adaway was one of my top reasons why I wanted rooted phone and with Samsung there is so many unwanted stuff installed as default apps. They take up so much space, ram, battery. They probably wouldn't so useless if I lived in US, because they would work there, but none of them are supported in Finland.
https://linustechtips.com/topic/773904-help-with-unrooting/#findComment-9763928
