Help....
Go to solution Solved by xAcid9,
1 minute ago, Nickathom said:
no im doing it through windows
It's similar.
http://www.overclock.net/t/1353325/tutorial-atiwinflash-how-to-flash-the-bios-of-your-ati-cards/0_20
I flashed my bios like a retard and ruined one of them. The thing is, whenever i try to fix the other one it gives me a subsystem id mismatch, which is retarded because i literally took the bios.rom from my 2nd other bios. Please help...
13700k, 3070, 32GB@3200
https://linustechtips.com/topic/773745-help/
Which cards? (model and brand and make please)
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
https://linustechtips.com/topic/773745-help/#findComment-9761898
Use the force Luke.
ok you just need to use Force flash parameter. -f
https://linustechtips.com/topic/773745-help/#findComment-9761914
And I suppose you did not backup the first bios right?
My Machines:
The Gaming Rig:
My good old laptop:
Lenovo T430
-4GB DDR3 1600MHz
-Not even 1080p
https://linustechtips.com/topic/773745-help/#findComment-9761915
2 minutes ago, Nickathom said:
in what order?
U use Atiflash thru DOS right? Not CMD Prompt.
https://www.techpowerup.com/forums/threads/how-to-use-atiflash.57750/
Quote
*Note* To use more than one command, just add the addition commands afterwards
ex. atiflash -f -p biosname.bin
https://linustechtips.com/topic/773745-help/#findComment-9761924
It's similar.
https://linustechtips.com/topic/773745-help/#findComment-9761936
4 minutes ago, xAcid9 said:
it worked!!! thank you so much... now to try and get a 580 bios on here :P
https://linustechtips.com/topic/773745-help/#findComment-9761961
Make sure you keep your card original BIOS somewhere, they are precious. :P
https://linustechtips.com/topic/773745-help/#findComment-9761964
