1- What PSU is that? 500W is just its wattage, what is its model?
2- Can you get CPU/GPU temperatures while gaming?
3- Does this only apply to CS GO and that specific map? Are you sure all the other games and maps run without performance issues?
4- How big is the frame drop?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/773496-help-fps-drop/#findComment-9759155
1- evega 500 watts psu
2- cpu 25~ gpu 24~ while gaming cpu 45-50 gpu 40~
3- havet played all maps but just checked with bots, cache 90-200fps mid connect/t-spawn 90-110 fps is lowest on that map. Mirage mid 130fps, a-site 120-160fps. inferno mid 80-100fps
https://linustechtips.com/topic/773496-help-fps-drop/#findComment-9759237
1-Which EVGA PSU is that? I need to know the make not the brand.
https://linustechtips.com/topic/773496-help-fps-drop/#findComment-9759898
An i7-7700K and GT-1060 would play CSGO with a 350watt power supply (or even less). The power supply is not likely to be the problem.
If it's just certain maps, it could be file corruption.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/773496-help-fps-drop/#findComment-9760631
