Help with switching drives
Go to solution Solved by astrosheen,
10 minutes ago, infiniteblessing said:
hey, I have an HDD with pretty much everything on it, including windows. How can I transfer the info to an SSD so I can use that as my main, Do I need a special chord or something?
You would be much better off doing a fresh install of windows and reinstalling what you need. I know it is painful (I've done it around 4-5 times) but worth it. It is likely that what you have on the HDD will not fit on the SSD but you might be lucky or have a large SSD so you will need to delete stuff anyway. There is plenty of good cloning software out there and some SSD's come with some to use.
@infiniteblessing
Cloning a HDD to an SSD is technically possible but realistically its very likely not possible.
How big is the HDD and how big is the SSD?
To answer your question, nope, no special anything required. Just connect both drives to your motherboard then run the cloning software, select source and destination and hit clone.
Main Rig:-
Server:-
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
