Any AM2/AM2+ experts? Help!
Solved by Guest,
Did a google search, and had to look at some older topics.
BIOSTAR TFORCE TA790GX3 A2+ AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard
You might have to go used, because they are out of stock @ that store. So: yes, there are those kind of boards. Just look on ebay or sites like it.
