So I'm going to be running DDR4 in a 2 x 8 16GB set and I am wondering which speed to get. I did watch the video LTT made on RAM speeds but I didn't take much from it like usual. I am okay with spending an extra 20 dollars for a 3200 kit if it's worth the minimal gain I'll probably get in gaming.
Here are the sets I was looking at depending on what speed is recommended:
https://www.newegg.com/Product/Product.aspx?item=N82E16820233859
https://www.newegg.com/Product/Product.aspx?Item=N82E16820148985&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
https://linustechtips.com/topic/772894-right-memory-speed/
What are your full specs?
If you're on a Z-board, go with 3000 or 3200MHz.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/772894-right-memory-speed/#findComment-9753096
Just now, ripper101 said:
I'm upgrading to a 7700k on z270
Go with 3000MHz or 3200MHz. It's the best pricing that I've seen. After that the cost/MHz slope, goes down.
https://linustechtips.com/topic/772894-right-memory-speed/#findComment-9753103
