Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/772640-keyboard-help/#findComment-9750058
https://www.amazon.com/Cooler-Master-MasterKeys-Mechanical-Keyboard/dp/B01D3BDNF6/ref=sr_1_4?ie=UTF8&qid=1493416878&sr=8-4&keywords=cooler+master+keys
I have the Medium of this with White Led and Brown Switch. Can say I like it quite a bit, minus the bit of branding but my tower is also branded once on the front :P
It's on sale now for 120 US, You want a full size Keyboard? If it's not on sale it might be out of budget.
Only thing the medium size may have is lights for Caps lock, scroll, and numlock which is pretty minimal.
https://linustechtips.com/topic/772640-keyboard-help/#findComment-9752936
