What power supply, what storage, what case? -Specifically.- saying 450w isnt enough.
4 minutes ago, Jorbee said:
Budget is 400$ (can go a little over) Canadian
I need a
CPU
Motherboard
Ram
SSD (optional)
GPU
I already have a case, power supply, storage, and case fans.
Power supply is 450 watts
If you have a 400 budget maybe skip the SSD
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($77.99 @ PC Canada)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($64.75 @ Vuugo)
Memory: G.Skill Aegis 8GB (1 x 8GB) DDR4-2400 Memory  ($69.99 @ Newegg Canada)
Video Card: Zotac GeForce GTX 1050 Ti 4GB Mini Video Card  ($183.99 @ PC Canada)
Total: $396.72
Generated by PCPartPicker 2017-04-27 23:43 EDT-0400
rip
Total: $396.72
BIOS update required, not going to work out of the box.
Motherboard: ASRock B250M-HDV Micro ATX LGA1151 Motherboard  ($74.50 @ Vuugo)
Total: $406.47
Generated by PCPartPicker 2017-04-27 23:46 EDT-0400
rip
