if i got a cut on my finger can i still unlock my iphone with my same fingerprint ?
Solved by Oshino Shinobu,
9 minutes ago, Nancy the Girl said:thank you for answering
I khnow I can use a passcode
but I just want to khnow if a cut on my finger can change my fingerprint completely for ever .
It can, as scar tissue doesn't retain the fingerprint. It can be re-registered with a scarred finger though. It would likely take a pretty serious cut to actually affect the fingerprint enough to stop it from registering.
If you get a cut that takes a significant amount of the "pad" of your fingertip, it's more likely to affect the fingerprint than just a normal cut.
