37 minutes ago, COTG said:
yep, using one from ebay tho
May I ask then, how did you go about installing it?
do you know if there is any way that I can download the windows version I am using on my current laptop onto a usb and use that one?
I don't believe you can do that because that install it's registered to your laptop.
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
https://linustechtips.com/topic/772283-need-help/page/2/#findComment-9746395
i used the media creation tool in order to create a bootable usb drive which I afterwards plugged into my pc and booted from.
I really dont see anywhere I could have made a mistake, as much as I'd like too as it would make things considerably easier... :(
https://linustechtips.com/topic/772283-need-help/page/2/#findComment-9746406
Actually, I'm wrong. The way you did it is correct. But what version (build) of windows are you running on your laptop?
My Systems:
F@H Rig:
HTPC:
Laptops:
NAS:
https://linustechtips.com/topic/772283-need-help/page/2/#findComment-9746536
