Question About VS - CLR C++ Project
Solved by CookieMaster,
#include "MyForm.h" using namespace System; using namespace System::Windows::Forms; [STAThread] void Main(array<String^>^ args) { Application::EnableVisualStyles(); Application::SetCompatibleTextRenderingDefault(false); FinalProject::MyForm form; Application::Run(%form); }
Include this into .cpp file, change code on header file.
