hey guys,
My lg g4 has given up on life - and currently i have a blackberry z10 as a temporary replacement - but it is not cutting it as almoust none of my daily apps work.
Should I wait until oneplus release their new flagship or should i order the 3T, or do you know about any more cheap international smartphones with good hardware?
thanks and regards
Malcolm
https://linustechtips.com/topic/772009-i-need-help/
I really like my Axon 7, but I only got it because the 3T doesn't support Verizon. I'd take a look at both of those and see which one suits you best (I think there's an Axon 7s coming out too?)
If you're able to wait for either of those then I'd do that instead of buying now
edit: 7s might not come:http://pocketnow.com/2017/04/19/zte-axon-7s-government
didn't realize the Axon 7 was only $330 now, I'd take that asap
https://linustechtips.com/topic/772009-i-need-help/#findComment-9742437
