I have a GTX 1070 and an I5. But 3 weeks ago something happened. Before this I would get my 60 FPS that I get with Vsync. But after that all my games just randomly started to run very slow. I just get 7 FPS in GTAV and under 20 FPS in Simcity. I think that my GPU isn't getting used to it's full potential or something. I'm running Windows 10. Have anyone else had this problem?
https://linustechtips.com/topic/771550-low-fps/
Have you got the latest driver?
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/771550-low-fps/#findComment-9736819
Try downloading an older driver pre you having issues and install that after wiping the driver currently installed.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/771550-low-fps/#findComment-9736898
Just now, Wille said:
It's ITX and I just have 2 sticks. I'll try that tomorrow. But I think it's some problem with drivers.
Sounds pretty severe for a driver issue. Faulty RAM is usually the culprit in cases like this. Driver issues would be much more easily solved however :|
“sufficiently advanced technology is indistinguishable from magic still going to require driver rollbacks when it stops working for no reason“
https://linustechtips.com/topic/771550-low-fps/#findComment-9736931
5 minutes ago, Wille said:
I tried this once before I factory reseted my computer. Maybe I should try it again.
That would be the only thing I could think of.
Unless your system isn't properly being cooled.
https://linustechtips.com/topic/771550-low-fps/#findComment-9736955
