How does this white build look? How can I improve it? Gaming, rendering, editing, virtual machines. All on a $1500 budget not including peripherals or monitor.
PCPartPicker part list: https://pcpartpicker.com/list/9ww4JV
Price breakdown by merchant: https://pcpartpicker.com/list/9ww4JV/by_merchant/
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($338.34 @ OutletPC)
CPU Cooler: Deepcool CAPTAIN 240EX WHITE 153.0 CFM Liquid CPU Cooler  ($82.49 @ SuperBiiz)
Motherboard: Asus PRIME Z270-A ATX LGA1151 Motherboard  ($156.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($122.99 @ Best Buy)
Storage: OCZ RD400 256GB M.2-2280 Solid State Drive  ($174.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.88 @ OutletPC)
Video Card: Asus GeForce GTX 1070 8GB Dual Series Video Card  ($369.00 @ Amazon)
Case: Deepcool DUKASE WHV2 ATX Mid Tower Case  ($54.99 @ Amazon)
Power Supply: Deepcool 750W 80+ Gold Certified ATX Power Supply  ($74.99 @ Newegg)
Case Fan: Deepcool TF 120  WHITE 76.5 CFM  120mm Fan  ($14.99 @ Newegg)
Other: CableMod WideBeam Magnetic RGB LED Strip – 60cm ($19.00)
Total: $1506.63
Generated by PCPartPicker 2017-04-25 15:26 EDT-0400
IM BACK BABY
https://linustechtips.com/topic/771529-1500-white-build-help/
get a h100i or x61 AIO.
get higher capacity SSD for that price
https://linustechtips.com/topic/771529-1500-white-build-help/#findComment-9736702
I would suggest an intel NVME ssd like : intel 600p 512
https://pcpartpicker.com/product/w34NnQ/intel-600p-series-512gb-m2-2280-solid-state-drive-ssdpekkw512g7x1
https://linustechtips.com/topic/771529-1500-white-build-help/#findComment-9736722
Total: $1506.63
get a ryzen build,
those will not work well on a 4x/8t build, a 1700 with 8c/16t will be much better.
https://linustechtips.com/topic/771529-1500-white-build-help/#findComment-9736734
Heres what I came up with
CPU: AMD RYZEN 7 1700X 3.4GHz 8-Core Processor  ($379.89 @ OutletPC)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($89.49 @ Amazon)
Motherboard: Asus PRIME X370-PRO ATX AM4 Motherboard  ($158.49 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  ($119.99 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($69.99 @ SuperBiiz)
Total: $1574.79
Generated by PCPartPicker 2017-04-25 16:22 EDT-0400
https://linustechtips.com/topic/771529-1500-white-build-help/#findComment-9737023
44 minutes ago, nerdslayer1 said:
get a ryzen build,
46 minutes ago, mcaldwell said:
How is this as a revised list! @deXxterlab97 @Being Delirious
PCPartPicker part list: https://pcpartpicker.com/list/JbmRbj
Price breakdown by merchant: https://pcpartpicker.com/list/JbmRbj/by_merchant/
Motherboard: MSI X370 GAMING PRO CARBON ATX AM4 Motherboard  ($173.89 @ OutletPC)
Storage: Samsung 960 EVO 250GB M.2-2280 Solid State Drive  ($127.98 @ NCIX US)
Total: $1518.07
Generated by PCPartPicker 2017-04-25 16:19 EDT-0400
IM BACK BABY
https://linustechtips.com/topic/771529-1500-white-build-help/#findComment-9737030
Total: $1518.07
Dexxterlab97 is no longer on the forum. Looks good!
lttstore.com
https://linustechtips.com/topic/771529-1500-white-build-help/#findComment-9737036
CPU: AMD RYZEN 7 1700 3.0GHz 8-Core Processor  ($316.88 @ OutletPC)
CPU Cooler: Phanteks PH-TC12DX 68.5 CFM CPU Cooler  ($49.99 @ Newegg)
Motherboard: MSI B350 TOMAHAWK ARCTIC ATX AM4 Motherboard  ($118.99 @ SuperBiiz)
Storage: Crucial MX300 525GB 2.5" Solid State Drive  ($149.99 @ Amazon)
Case: Phanteks ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($99.98 @ Newegg)
Power Supply: EVGA SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.49 @ SuperBiiz)
Case Fan: be quiet! Pure Wings 2 61.2 CFM  140mm Fan  ($11.33 @ OutletPC)
Total: $1419.18
Phanteks will send you an AM4 mounting bracket.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/771529-1500-white-build-help/#findComment-9737158
CPU Cooler: Enermax ETS-T50 AXE (White) 62.3 CFM CPU Cooler  ($51.99 @ Directron) get mounting kit from enermax website.
Motherboard: ASRock X370 KILLER SLI/ac ATX AM4 Motherboard  ($138.98 @ Newegg)
Storage: Crucial MX300 525GB M.2-2280 Solid State Drive  ($146.98 @ Directron)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Amazon)
Video Card: EVGA GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card  ($494.98 @ Newegg)
Case: Phanteks ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($89.98 @ Newegg)
Power Supply: BitFenix Fury 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($78.69 @ SuperBiiz)
Total: $1498.46
Generated by PCPartPicker 2017-04-25 20:13 EDT-0400
https://linustechtips.com/topic/771529-1500-white-build-help/#findComment-9738331
https://pcpartpicker.com/list/nPFqyf
Go with a Ryzen CPU if your going to do anything besides gaming, even if gaming is 80% of what you'll do. The difference in multi-core performance is far more beneficial than Intel. It's slightly over budget with a $30 OS key, but it's not too insane. Managed to squeeze everything that you'd need.
https://linustechtips.com/topic/771529-1500-white-build-help/#findComment-9739080
