Switches
Solved by ProjectBox153,
1 minute ago, mattbatc said:I like the idea of multiple switches because it allows me to easily switch something out if it breaks. And because I'm moving to college soon, this will make it much easier for my parents to fix any issues that arise while I'm away
Oh, I see. That's fine then, just make sure you know how many ports are needed (and take into account the ones for the other witches) and get something decent.
