Hey all,
I have a OnePlus 3T and was wondering if its possible to get the Samsung Gear VR apps and such to work on it?
Obviously I know the screen is sub par for VR, but the Gear Gen 2 is only £44 on Amazon at the minute and seems worth a try.
But will I be able to download all the necessary apps and stuff without being on a Samsung handset?
Cheers,
Ez
DAEDALUS (2018 Refit) - Processor: AMD Ryzen 5 - 1600 @ 3.7Ghz // Cooler: Cooler Master Hyper 212 LED Turbo Black Edition // Motherboard: Asus RoG Strix B350-F Gaming // Graphics Card: Gigabyte GTX 1060 Windforce 6GB GDDR5 // Memory: 2 x 8GB DDR4 Corsair LPX Vengeance 3000Mhz // Storage: WD Green - 250GB M.2 SATA SSD (Boot Drive and Programs), SanDisk Ultra II 120GB (GTA V), WD Elements 1TB External Drive (Steam Library) // Power Supply: Cooler Master Silent Pro 700W // Case: BeQuiet Silentbase 600 with SilentWings Mk.2 Internal Fans // Peripherals: VicTop Mechanical Gaming Keyboard & VicTsing 7200 DPI Wired Gaming Mouse
PROMETHEUS (2018 Refit) - Processor: Intel Core i5-3470 @ 3.2Ghz // Cooler: Cooler Master 212 EVO // Motherboard: Foxconn 2ABF // Graphics Card: ATI Radeon HD 5450 (For Diagnostic Testing Only) // Memory: 2 x 4GB DDR3 Mushkin Memory // Storage: 10TB of Various Storage Drives // Power Supply: Corsair 600W // Case: Bitfenix Nova Midi Tower - Black
SpeedTest Results - Having Trouble Finding a Decent PSU? - Check the PSU Tier List!
https://linustechtips.com/topic/770901-oneplus-3t-gear-vr/
10 minutes ago, M.A.P said:
It is possible assuming that Oneplus 3t will physically fit into Gear VR but requires root so warranty voided. If you are having no problem voiding warranty then go ahead. Here is detailed information in XDA Developers page.
Bugger, I just ordered a £10 version since it was same day delivery to mess around with.
I might try the Gear VR software you linked to and see if it works with the knock off headset I just bought xD
https://linustechtips.com/topic/770901-oneplus-3t-gear-vr/#findComment-9729586
No it will not work as Gear VR connects through USB type C or USB 2.0 and also has few buttons which are only present on Gear VR so not at all possible.
https://linustechtips.com/topic/770901-oneplus-3t-gear-vr/#findComment-9729591
