Since it says that java isn't completely installed, I'd suggest you reinstall java completely.
CPU: Intel Core i5 4690K @ 4.6Ghz CPU Cooler: Noctua NH-D15 GPU: GTX 1070 TI RAM: Crucial Ballistix Tactical 16GB (4x4) Mobo: ASUS Z97-PRO(Wi-Fi ac) PSU: Corsair RM Series RM750 Case: Fractal Design Define R4 no window
https://linustechtips.com/topic/770699-java-help/#findComment-9727276
On 2017-4-23 at 11:36 PM, HighRez said:
As I said in the post, I did try this. Maybe I'm not fully uninstalling? I was uninstalling via programs/apps.
Thanks.
have you tried revo uninstaller pro? It has a free trail if you're interested. You can even but it for $1 right now on the humble bundle.
https://linustechtips.com/topic/770699-java-help/#findComment-9740514
