Gaming Build Advice
Go to solution Solved by ChalkChalkson,
15 minutes ago, Mr.Meerkat said:
What I'd recommend :)
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  (£209.99 @ Amazon UK)
Motherboard: ASRock AB350M-HDV Micro ATX AM4 Motherboard  (£65.79 @ CCL Computers)
Memory: Corsair ValueSelect 16GB (1 x 16GB) DDR4-2133 Memory  (£108.15 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£41.95 @ Amazon UK)
Video Card: MSI Radeon RX 480 8GB ARMOR 8G OC Video Card  (£199.98 @ Novatech)
Case: Zalman ZM-T3 MicroATX Mini Tower Case  (£25.99 @ Amazon UK)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£49.97 @ Ebuyer)
Total: £701.82
Generated by PCPartPicker 2017-04-22 22:51 BST+0100
It's 50 overbudget but its worth it IMO :P
Else get a 4GB rx480 ;)
Video Card: Asus Radeon RX 480 4GB Dual Video Card  (£177.23 @ BT Shop)
Total: £679.07
Generated by PCPartPicker 2017-04-22 22:59 BST+0100
I am not sure if the 1600 is worth the extra 50 bucks compared to a simple i5
since you used pounds I assume you live in the UK :)
Do you have a strong preference towards new parts, or a used ones ok?
How about your periferals, do you have a freesync monitor, or consider going with adaptive refreshrate in the future?
How intense do you use Premiere Pro? Do you use (I think they are in Aftereffects) tools like camera tracking/stabilization?
Is your workflow highly CPU dependent, or are you using GPU accelerated codecs?
What games are you going to play? More on the AAA side (Assassin's Creed, GTA V, CoD etc) or more focused on strategy-style games with simpler visuals and intense calculations (Cities Skylines, EU4/HOI4..) or are you mostly playing E-Sports titles?
Are you recording/streaming/rendering while you are gaming?
I hope to hear from you, since this information is needed to give you the best advise possible
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9722464
New parts would be a preference as in my opinion it is still relatively hard to find used parts.I also will be using light editing.Maybe  light use of aftereffects wouldn't mind if the render times are longer on that as long as it is usable.Mostly AAA games.I am not to informed about the codecs .I am buying everything new(First Build...EXCITED!!!) So I will buy the monitor separately not in the budget.I will also be recording however  I am fine with tuning down game settings for recordings.Thanks for helping me as the budget is kinda of an issue to squeeze out as much performance as i possibly can with a low budget .
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9722481
So with this list you can go with pretty much no big compromises, semi modular PSU, case with room for cables, a 240GB SSD, a quadcore and a fairly decent videocard.
I know that this is slightly over budged but I would not recommend stepping down even further on any of the components.
If you need more storage right now and can't salvage a harddrive from an old PC, or wait until you can afford one, you can switch the SSD out for a cheap 1TB HDD from Seagate or WD no problem. Note however that this will slow your daily experience down significantly
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9722570
Total: £701.82
Total: £679.07
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9722635
Total: £701.82
Total: £679.07
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9722689
Hmmmm...1.5x more cores and 3x more threads...I'm sure premiere will love it :P
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9722704
Premier will probably like it, and it is sure as hell a better CPU, the question is, if OP can afford it and/or how much other cut offs will be need to afford it. I can't answer that.
If OP can afford it without huge problems he should go with it. But if this is a strict budged that can't be stretched too much, an i5 is still a good option, since it is the cheapest quadcore atm
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9722728
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  (£83.99 @ Amazon UK)
Power Supply: XFX TS 430W 80+ Bronze Certified ATX Power Supply  (£38.74 @ More Computers)
Total: £643.68
Generated by PCPartPicker 2017-04-22 23:26 BST+0100
Izi pizi :)
edit: Here the same build but with a nicer case...
Case: Thermaltake Versa H15 MicroATX Mid Tower Case  (£34.98 @ Amazon UK)
Total: £652.67
Generated by PCPartPicker 2017-04-22 23:28 BST+0100
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9722734
Total: £643.68
Izi pizi :)
Total: £652.67
I have no experience with the XFX PSU, I know that their GPUs are decent, but if the PSU is scetchy in any way I would stay away from it, since a poorly made PSU is actually physically hazardous.
I would also go the extra mile and get an SSD in there if at all possible
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9722794
Hmmmm...well there's this saying in the PSU world "Any XFX bar the XT line" which basically means as all XFX PSUs are made by Seasonic (the XT line is designed by SS but outsourced so is kinda crap), you can bet its made with decent quality components and performs well enough.
I mean seasonic after all is known to be safesonic as all units made by em are rather good...even the ones you find in prebuilts...
Well 240GB is not enough for some people ya know...also, have you ever tried using a 7200RPM desktop hard drive as the OS drive with a fresh install?
My friend who only uses his PC for gaming only has a 500GB WD blue with zero bloatware/crap on startup and can boot into windows 7 2 seconds slower than my MX100 and my ol' 850 EVO (or faster if you include posting) so...hard drives aren't that bad...assuming there's no shitty bloatware installed :P
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9724783
As I said, no experience with XFX, so I do not have any opinion.
As of the SSD vs HDD, yeah, boottimes are kinda ok, especially with hybrid drives, but in daily work you feel it. Believe me, I tried.
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9734616
I think everyone has experienced HDDs...
I mean my old laptop had a 90/90MBps seq read/write 2.5" 5400RPM and I got on with it fine...just :P
https://linustechtips.com/topic/770209-gaming-build-advice/#findComment-9735857
