i recently cleaned my computer using a can of compressed air and found that my audio coming from my speakers was distorted when i went back on my pc i have tried to fix the problem in a number of different ways. the first way way replacing my aux cable however this did nothing. i also tried plugging the audio cable it to my front io and the io on the motherboard at the back however this did nothing. i have also tried plugging in another speaker via aux and the same distortion occurs for this reason i know that the problem does not lie in my speakers or any of the hardware however i have also updated my drivers via device manager with no change to the audio.
the distortion that i am hearing from the speakers is that of a fractured sound with static and a fan like sound (fractured) . the sound only occurs at certain pitches often in the lows.
i have not found a solution online and am looking for an answer, i was thinking that maybe i have damaged something internally e.g.the  HD audio socket and have unplugged and plugged it without a change in the situation
does this occur when you have another source?
(phone, laptop, tablet, etc)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
i plugged the speakers into my phone and they work fine whilst connected to the phone the problem only occurs when the speakers are plugged into the PC the distortion happens with all audio devices i plug into my PC (other speakers, headphones etc.)
Probably motherboard. My speakers did the same as well as my older headphones. Motherboard had too much electrical interference going to the audio jacks. That all went away with my Corsair voids thanks to USB. My guess is that its either Electrical interference or you damaged it. If its electrical interference then there's nothing you can do about it or at least thats what im aware of. Same goes for the situation that the motherboard is actually damaged
Primary Laptop (Gearsy MK4): Ryzen 9 5900HX, Radeon RX 6800M, Radeon Vega 8 Mobile, 24 GB DDR4 2400 Mhz, 512 GB SSD+1TB SSD, 15.6 in 300 Hz IPS display
2021 Asus ROG Strix G15 Advantage Edition
Secondary Laptop (Uni MK2): Ryzen 7 5800HS, Nvidia GTX 1650, Radeon Vega 8 Mobile, 16 GB DDR4 3200 Mhz, 512 GB SSD
2021 Asus ROG Zephyrus G14
Meme Machine (Uni MK1): Shintel Core i5 7200U, Nvidia GT 940MX, 24 GB DDR4 2133 Mhz, 256 GB SSD+500GB HDD, 15.6 in TN Display
2016 Acer Aspire E5 575
Retired Laptop (Gearsy MK2): Ryzen 5 2500U, Radeon Vega 8 Mobile, 12 GB 2400 Mhz DDR4, 256 GB NVME SSD, 15.6" 1080p IPS Touchscreen
2017 HP Envy X360 15z (Ryzen)
PC (Gearsy): A6 3650, HD 6530D , 8 GB 1600 Mhz Kingston DDR3, Some Random Mobo Lol, EVGA 450W BT PSU, Stock Cooler, 128 GB Kingston SSD, 1 TB WD Blue 7200 RPM
HP P7 1234 (Yes It's Actually Called That)  RIP
Also im happy to answer any Ryzen Mobile questions if anyone is interested!
