Hi, I would like to have your opinion on my game PC build and how to improve or save money. if you also would like to tell me if the parts are compatible with each other, would be nice.
my budget is max €800 but I like it to be less. parts in the Netherlands are a bit more expensive so 200 dollars in the USAs is 220 euros here.
Pcpartpicker list: https://de.pcpartpicker.com/list/CKHGRG
thanks
Extra: what you think of the AOC G2460VQ6 monitor?
Daanyy_Kong
Edited by Daany_Kong
https://linustechtips.com/topic/770109-need-help-building-gaming-pc/
2 minutes ago, Daany_Kong said:
that would be to expensive
https://de.pcpartpicker.com/list/kkfyTH
€750.86
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
1 minute ago, Daany_Kong said:
Yes, sorry forgot to include in the post. this are the prices in Germany the price in the Netherlands is €790,71
that's still under €800 :P you guys include VAT, where in north America its fucking stupid that they don't
Just now, Daany_Kong said:
were talking about the ryzen 1600 right? the ryzen 1600 is €239,0 and the 1500 is €209
yes, we're talking about the ryzen 1600
it's still under budget, and you get 2 more cores
in the pcpartpicker, the PSU doesn't have a price
this is the site I'm ordering on https://azerty.nl/basket/?code=YTo3OntpOjM4NTQ0NztpOjE7aTo3MTExMDtpOjE7aToxNTUwMzM7aToxO2k6MzIxNjg7aToxO2k6MTYzNjc4NjtpOjE7aToxNTk4MjQ0O2k6MTtpOjE2MjAzOTU7aToxO30= (not sure if you can see this)
I don't read .. dutch?
thanks
Daanyy_Kong
Going off your build you posted,
your PC won't run at all. 1500x comes w/ no cooler, since it's more for overclocking, so you need to add a cooler.
So based on that, your better off going for a Ryzen 5 1600 over the 1500x, since that extra $30 will be a cooler anyways, but the 1600 comes w/ a stock wraith cooler, and you get more stuff.
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
the site? yes
from Canada, only can read English :P
12 minutes ago, Daany_Kong said:
the site i'm ordering on says wraith spire cooler included
Doubt that, since the rule of thumb was X behind the numbers is a giveaway it has no stock cooler. It was true for the Ryzen 7, so unless they completely did a 180 on stuff (good ol AMD), then you might be correct.
@deXxterlab97 you know anything by chance?
edit: Looks like your right, my bad, didn't realize they made it less obvious.
https://azerty.nl/basket/?code=YTo3OntpOjE2MjAzOTU7aToxO2k6NzI4NDQ4O2k6MTtpOjE2MDM0ODc7aToxO2k6MTAzMDE7aToxO2k6MTY4NDM0O2k6MTtpOjM4NTM5NjtpOjE7aTozODU0NDc7aToxO30=
800e with R5 1600.
Alternative motherboard if you want to save 10e;
https://azerty.nl/product/asus/2599320/prime-b350m-a-moederbord-micro-atx
I wouldn't bother spending an extra 15e+ for an RX 580 over the 480, bit pointless IMHO.
Add an SSD asap.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
800e with R5 1600.
Add an SSD asap.
Hi, could you explain why this motherboard is better than the one I had?
Also, I thought 2x4gb ram is better than 1x8 and the 2x4gb I had was cheaper.
Do you think it is possible to include a semi-modular PSU in this?
I am including an SSD later this year when there is a good deal for it.
4 DIMM slots, as opposed to 2. Better build quality and better VRMs.
No, 2x4GB isn't necessarily better than 1x8GB. The RAM you were looking at was 2133MHz. The RAM I included is nicer and faster. I'd get 2666MHz+ RAM with Ryzen whenever possible though, since Ryzen likes faster RAM. Also, 1x8GB gives you more/easier RAM upgrades in the future. If you went with the Asrock motherboard that only had 2 DIMM slots and the 2x4GB RAM, you'd not be able to upgrade RAM in the future without replacing it completely. With 1x8GB, you can add another 1x8GB at any point and still have room to add more. I don't recommend anything less than 8GB sticks these days, but you can go with 2x4GB if you want.
It is possible to get a semi-modular PSU if you want, but it will put the cost up. Also, modularity isn't that huge a deal in a case like the S340. Modularity will help your cable management because it will be easier on you, but it won't affect aesthetics whatsoever, thanks to the S340's PSU shroud. This is the cheapest half decent semi-modular PSU I could find;
https://azerty.nl/product/corsair/926893/cx-m-series-cx650m-voeding--intern--atx12v-2-4-eps12v-2-92
thank you!
