Sennheiser HD 201 w/ Antlion Audio ModMic 4.0
Guest Storm10
The Antlion Audio ModMic 4.0 works with almost all headphones and does it work with this one?
The ModMic would work on a lamp, a spoon, a bottle of coca cola, a piece of paper, your mouse... pretty much anything that a piece of adhesive can attach itself to,
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
@Storm10 Yep it's just a clip that splits into two pieces with a magnet that holds the 2 pieces together with adhesive on one end.
Case - Fractal Design Arc Mini R2 : Mobo - Asus Maximus VI Gene : PSU - Corsair AX760 : CPU - Intel i7 4790k w/ EK-Supremacy EVO Copper/Acetal Water Block  : Memory - Corsair Vengence Pro 24gb 1600mhz : GPU - Evga GTX 780 Ti Classified w/ EK-FC780 GTX Classy - Acetal+Nickel Water Block : Storage - Samsung 840 Evo 250gb & 850 Evo 1tb SSDs, 2x 6TB External HDDs : Fans - 5x Noctua NF-F12 & 1x NF-S12A : Display - 24in Benq XL2420TE : Rads - Darkside LPX360 & LP240 : Pump/Res - EK-XRES 140 D5 Vario Pump
