In November, 2016, I built my first PC after saving a lot of money. Just yesterday, after coming home from school, I tried powering on my PC but here's what happened:
I hit the power button on the case, and I heard the usual fans and hard drive spin up and such, but nothing showed up on the display.
 3-5 seconds later, it just randomly shut off.
5 seconds later it just turned back on.
Another 3-5 seconds had passed and it turned off again.
Every time I hit the power button it goes through this process but never actually powers on.
It's been doing this ever since yesterday (unless I flip off the PSU switch).
Here's a video of what it looks like
I have no idea what to do and would appreciate any help possible.
I attached a video of what happens.
Specs:
CPU: i7 6700K
GPU: GTX 1070
MOBO: Gigabyte GA-Z170X-Gaming 7
RAM: Corsair Vengeance 16 x 2 32 GB RAM
PSU: EVGA SuperNOVA 750 G2
(let me know if you need to know more anything else)
HELP PLS.mp4
https://linustechtips.com/topic/769728-i-need-help-asap/
I'd had this issue before. It was a problem with overclocking. Have you overclocked recently? Any changes in the BIOS?
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9717198
Reset CMOS. If it still boot loops then it is most likely a hardware problem.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9717221
5 minutes ago, likeabog said:
I have not overclocked at all after building.
Alright, have you checked the ram? Is it correctly seated? Also does your motherboard have an LED error code? See what it says and check the manual accordingly. Also check the CPU cooler make sure it's seated correctly.
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9717227
Just now, Abdul201588 said:
Alright, have you checked the ram? Is it correctly seated? Also do you motherboard have an LED error code? See what it says and check the manual accordingly. Also check the CPU cooler make sure it's seated correctly.
The RAM is seated. All the screws on the cooler are well-tightened and its seated properly. An error code doesn't show up on the debug either.
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9717234
This is very odd. :/ Check if anything is touching the motherboard, any cables. And like the others said, it could be a PSU issue.
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9717262
44 minutes ago, nerdslayer1 said:
RMA or switch out for another psu corsair 80+ 500 watt will work.
@likeabog
I am with everyone who said "PSU". This is a very common occurrence. The first time I saw it I was doing a network job for a law firm and was baffled at one of their PC's. I brought it to the shop (Now I had spare PSU's in the Van) and my boss thanked me for the extra $ I made him for something I should have known and done on site.
The PSU should still be under warranty if you built the PC in 2016. If you want to make sure before you send it out, try booting up with another psu if you have one available. Also, does it boot without the graphics card in? Even if it does, I still think it's the PSU just not delivering enough juice.
There is enough youth in this world, how about a fountain of smart?
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9717334
I'd recommend more power, just to be onthe safe side.
https://www.newegg.com/Product/Product.aspx?Item=9SIA68V21E0633
Yeah yeah, it's listed as a tier 3 here, but I'm at a loss why, as it is a killer psu. Gold + rating and all.
If you want to go down too 650 watts the Be-Quiet Dark Power Pro kicks ass, and for the tier list fans is a tier 1 platinum ;) .
https://www.newegg.com/Product/Product.aspx?Item=9SIA68V39G8952&cm_re=Be_Quiet_DARK_POWER_PRO_10-_-1HU-004H-00053-_-Product
They are both the same price,1 is a 750 watt, the other a 650.
Either way, they should last you for quite awhile. They both have 5 year warranties, but I doubt you will have to deal with them letting you down.
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9717392
25 minutes ago, crzyces said:
@likeabog
So you're saying that you could've fixed it on site but decided to take it to your bosses shop to get more money from said law firm?
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9717423
No, absolutely not. I had no idea what was wrong with it, I tested the psu with my multi, it was testing fine, so I was lost. Problem was, I just *checked*, the PSU would output it's 400 watts or whatever for 5 seconds or so, then drop off. I wasn't testing for minutes at a time, just a quick test, so I never saw the drop off in output. I was new, and had never seen that issue. It never occurred to me to swap the PSU as it read correctly on the meter. I was paid the same regardless at the time, so juicing customers didn't make me a nickle extra.
Edited by crzyces
Had to explain a bit better.
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9717465
500 watt is more than enough, gold rated doesn't mean it's good.
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9717520
Lol I'm sooo glad I asked before I put you on blast. xD
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9717564
Try to clean your ram with rubber eraser and try 1 ram in each slot and see if the pc post.
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9734435
1 hour ago, openthatchest said:
rubber eraser???
That is a new one for me too. A wipe with a static free cloth and compressed air (or even a blow dryer) in the seats is normally fine. Lol, what is gunked on RAM that you need an eraser to get it off?
https://linustechtips.com/topic/769728-i-need-help-asap/#findComment-9738945
