extend ethernet
Solved by Blake,
14 minutes ago, happy57110 said:is there any way to extend the range of your ethernet cable without using poe because i heard that if i plug in poe to a non poe device it will fry it. i just want to know how to make the range of the ethernet cable longer before the data starts degrading
Nah, POE wont fry a non-poe device. This is assuming that the POE is following the correct standards (i.e. non-poe devices just don't bridge the specific pins so no circuit is formed).
If your looking for a long single run use a different Ethernet standard - ie. LX is fiber up to 5km, all the way to ZX which is up for 73km or something massive.
