5 minutes ago, nunocv said:
Phanteks P400S vs Nox Hummer ZN vs Fractal Define S vs Cooler Master Silencio 550
(None with windowed side panel)
Which is the better one?
Define S has better airflow meaning your GPU fans and system fans won't have to run as fast to keep the system cool and thus quiet. It's also built with foam and thick metal. Would recommend.
https://linustechtips.com/topic/769328-best-silent-case/#findComment-9712107
Should I replace the fans with Noctuas?
Why did I study Haskell?
https://linustechtips.com/topic/769328-best-silent-case/#findComment-9712146
