So I built myself a brand spanking new PC and everything actually worked! It was time to install Windows 10. Put in the disk did some things off a YouTube video I watched and installed Windows! I restarted the computer to make sure all was good. I launched into the file explorer when I noticed... it installed as 32 bit! I (thought I) needed 64 bit. As well as one of my partisans needed to be formatted (remember that). So I attempted a reinstall. When I got confused in the Custom install menu. So I decided "Never mind I will just live with 32 bit and figure out a different way to format. " But it wouldn't let me back in to windows. So I had to reinstall it. Then (because I was very lost and confused) I decided to format all the partisans I made. ALL OF THEM. So now I can not install windows on any of them.  So since I had nothing on the HDD I decided to wipe the hard drive of anything. Let it do the thing for about an hour then said, "sorry, we ran into a problem while resetting your PC. I think I put my PC into a never ending pit. I think I need to get a new HDD now. Plz help
https://linustechtips.com/topic/769268-serious-hard-drive-problems/
Depending on the size of the hard drive, your best bet may be to just get a new HDD for cheap, about $10. Then use the other one for mass storage
CPU: Ryzen 5 1600 MOBO: MSI Tomahawk B350 GPU: Reference cooled GTX 980 Storage: Intel SSD5 256Gb RAM: 8gb Geil EVO Potenza Case:  Phanteks p300 PSU: EVGA 500 watt CPU Cooler: AMD wraith spire
Steam: maxarooni4
Battle.net: MAX
If you have an Oculus HMU in dead and buried
I'd rather not have to get a new one yet. I want to try all that I possibly can before I need to.
If you can boot back in to your installation media, try deleting all of the partitions made instead of formatting them. You should wind up with an empty disk that will allow for the installation to proceed. If you have access to a second computer you can kill two birds with one stone and just use the Windows 10 Media Creation tool available here to create a bootable USB that will install the 64 bit OS instead of the 32 bit.
I think the tool requires a 4GB USB drive (after formatting) if it is handling the media creation. I know the actual ISO size for Windows 10 is a bit smaller, so if your USB drive is right on the edge, you might opt to have it create an ISO file and use a tool such as Rufus to make a bootable USB off of that.
Would that mean I have to have that USB in the computer every timeI launch it up?
@thebrain36 When you have made the USB drive bootable using Rufus or the Media Creation Tool it will show in BIOS as a bootable media just like a Disk Drive or Hard Drive (Usually F12). I might be able to find something that will show a step by step if you can give your motherboard model. Give me a minute and i'll throw together some screengrabs of the step by step of the Media Creation Tool.
Thank you so much! I really appreciate all that you've done!
Okay so, when you first run the tool and click through the license agreement, you should first see a page that asks what operation you want to use. You'll need to select "Create Installation Media (USB flash drive, DVD, or ISO File) for another PC"
After that, you should be prompted to select the Language, architecture, and edition you want to install. On this page, you may need to de-select the "Use recommended options for this PC" checkbox should the automatically detected options from the second PC not be what you need for your installation.
Next, you'll need to select which method of media you want to use. Note: I assumed your USB met the size requirements, so I went with USB. If this is not the case let me know and I can run through it again.
Lastly, you will need to select the USB drive you want to use for the media. Please be certain you are selecting the right drive as after this point the drive will be formatted and any data will be lost. If there is anything on the USB drive that you care about, make sure you save a copy elsewhere before proceeding. After clicking "Next", the tool will download Windows 10, verify the integrity of the download, and create the bootable USB drive.
Once finished, you will be able to select "Finished" and the tool will close. At this point, you can eject the USB drive and insert it in to your new PC. Turn on the PC and mash F12 during POST to access the Boot Menu (May vary depending on your motherboard, please refer to the manual for exact keystroke). From there you should be able to select the USB drive as the boot device and get back to the windows installation prompt.
Hope this helps.
1 hour ago, thebrain36 said:
It helps a lot!This might be a dumb sounding question (I'm still pretty new to everything xd) how do i enter into the bios thing? Do I spam the F1 button? @Avex
what motherboard?
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
AMd R2.0 LE @KOMTechAndGaming
who makes it?
