I would like some suggestions about a build I am planning. I am starting from scratch.
I have a monitor, but other than that I need to buy everything.
What I want?
 - I will use the computer for number crunching and gaming. Since I will use CUDA an nvidia GPU is a must.
 - The scientific number crunching will not run all the time. This will not be a machine running 24/7.
 - Max budget is around 750-800EUR. (I am in Germany)
My current idea of the build is the following:
Case: Thermaltake Versa H22
PSU: Thermaltake Hamburg 530W
CPU: Intel i5-7600 with stock Cooler
GPU: Zotax GTC 1050 Ti Mini
Memory: Corsair Vengeance LP 2X8GB
Storage: Seagate Barracuda 1TB
Motherboard: Maybe ASUS ROG Strix B250F. Not sure.
What do you guys think?
https://linustechtips.com/topic/769225-mid-range-build/
What I want?
for gaming a 1500x over a 7600k, and what about a 1060?
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710694
You really want an R5 CPU for compute work
PCPartPicker part list: https://de.pcpartpicker.com/list/ksrxQV
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  (€241.42 @ Mindfactory)
Motherboard: ASRock AB350M-HDV Micro ATX AM4 Motherboard  (€80.30 @ Mindfactory)
Memory: ADATA 8GB (2 x 4GB) DDR4-3000 Memory  (€76.31 @ Amazon Deutschland)
Storage: Sandisk SSD PLUS 480GB 2.5" Solid State Drive  (€144.95 @ Amazon Deutschland)
Video Card: Zotac GeForce GTX 1050 Ti 4GB Mini Video Card  (€144.99 @ Amazon Deutschland)
Case: Aerocool Strike-X One ATX Mid Tower Case  (€24.19 @ Amazon Deutschland)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  (€72.74 @ Amazon Deutschland)
Total: €784.90
Less storage but better GPU
PCPartPicker part list: https://de.pcpartpicker.com/list/xJD4vV
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  (€84.99 @ Amazon Deutschland)
Video Card: Zotac GeForce GTX 1060 3GB 3GB Mini Video Card  (€205.00 @ Amazon Deutschland)
Total: €784.95
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710721
12 minutes ago, evilcman said:
If you can do 850 EU this is a beast
PCPartPicker part list: https://de.pcpartpicker.com/list/g8qqyf
Price breakdown by merchant: https://de.pcpartpicker.com/list/g8qqyf/by_merchant/
CPU: AMD Ryzen 5 1500X 3.5GHz Quad-Core Processor  (€211.84 @ Mindfactory)
Motherboard: Asus PRIME B350-PLUS ATX AM4 Motherboard  (€106.71 @ Amazon Deutschland)
Memory: G.Skill NT Series 16GB (2 x 8GB) DDR4-2133 Memory  (€109.93 @ Mindfactory)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€50.50 @ Amazon Deutschland)
Video Card: Zotac GeForce GTX 1060 6GB 6GB Mini Video Card  (€262.00 @ Amazon Deutschland)
Case: Thermaltake Versa H22 ATX Mid Tower Case  (€34.39 @ Amazon Deutschland)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  (€70.50 @ Amazon Deutschland)
Total: €845.87
Generated by PCPartPicker 2017-04-20 20:49 CEST+0200
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710732
Total: €784.90
Total: €784.95
1500x and a 1060 6gb. also hdd is fine
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710741
Go for ryzen if you don't mind or at least wait for i5 prices to drop.
A 1050 ti's performance per buck ratio is not that high. I would say a Zotac 1060 Mini 3GB will be better. If you don't mind getting older products (still in brand new, retail condition), you can get a 970 4GB.
If you decided to stick with the 1050 ti, you can use a 400W PSU from known brands like Antec, EVGA, Cooler Master sth like that with good customer reviews. Your overall set-up won't pull more than 300W under full load.
I don't recommend using Seagate drives. 2 hard drives from them died on me right after warranty expires.
Desktop benching:
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710754
1400/1500X isn't worth it, get the extra threads and a cheaper GPU while staying in budget.  Gaming isn't priority and the 1600 will easily win in number crunching therefore it is more important
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710757
1060 3gb has less cuda, he wants cuda cores too and games will be better, its better overall
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710771
Its a minimal difference when compared to the extra cores.
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710773
it is more balanced & better for gaming, while not sacrificing too much compute. also higher clocked cores help
The cores will OC to the exact same, plus your build goes way over budget.  Mine goes a bit high but yours blows it out of the park.
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710792
Well I'll just toss my two cents in here: ¿por qué no los dos?
R5 1600, 16GB RAM and a GTX 1060 all at 0.58€ over budget. (The only compromise here is that you will only have enough budget for one storage solution, replacing the SSHD with a SSD works great too, but I thought this was a good compromise)
PCPartPicker part list: https://de.pcpartpicker.com/list/Q9dnJV / Price breakdown by merchant: https://de.pcpartpicker.com/list/Q9dnJV/by_merchant/
Storage: Seagate FireCuda 1TB 2.5" 5400RPM Hybrid Internal Hard Drive  (€66.90 @ Amazon Deutschland)
Power Supply: XFX XT 500W 80+ Bronze Certified ATX Power Supply  (€46.43 @ Amazon Deutschland)
Total: €800.58
Generated by PCPartPicker 2017-04-20 21:02 CEST+0200
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710825
Total: €800.58
lol, thats the build I made, or close to it!
Total: €784.90
Total: €784.95
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710839
Sure is pretty close, the only differences really is the RAM choice, storage and motherboard. Though, I tried to stick to some of OP's original parts, like 16GB RAM, 1TB HDD and an ATX size mobo.
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710861
Oh shite, the RAM was an accident.  good catch, now fixed
PCPartPicker part list: https://de.pcpartpicker.com/list/kJ48wV
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  (€241.41 @ Mindfactory)
Memory: Corsair ValueSelect 16GB (1 x 16GB) DDR4-2133 Memory  (€106.89 @ Amazon Deutschland)
Total: €781.03
PCPartPicker part list: https://de.pcpartpicker.com/list/wK9T9W
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (€49.96 @ Amazon Deutschland)
Total: €805.47
https://linustechtips.com/topic/769225-mid-range-build/#findComment-9710916
