Hello, im looking to upgrade my current pc build but im having a hard time deciding if i should get an i5-7600 with a gtx 1060 3gb or an i7 7700 with a gtx 1050 ti. Im looking mainly towards longevity (i dont want to upgrade in a long time) and gaming at 1080p.
Additional info:
-I could stretch my budget and get an i7 7700 with a 1060 3gb or an i5 7600 and a 1060 6gb. but i dont really want to unless worth
-the price difference between i5 and i7 is around $120 dollars in here. The gtx 1050 ti: $180, 1060 3gb: $265 and 1060 6gb is $340.
-Not considering k processors because the price difference in buying a cooler and oc mobo is way too much in here. I also dont want amd.
-I dont really mind lowering some settings in some games to get better fps, what i want the most is not having to upgrade any time soon
https://linustechtips.com/topic/769103-help-with-upgrade/
"I don't want AMD" is the mindset that restricts you from getting a good PC. I suggest you ditch it.
There's little reason to grab a locked i5 nowadays with the release of AMD's R5 processors. The R5 1600 is a good medium between the i5 7600 and i7 7700... and you can also overclock it.
I suggest you skip the GTX 1060 3GB altogether. The limitations of 3GB is starting show, especially in texture heavy titles. The RX 480 8GB or GTX 1060 6GB are good choices. Just get the cheaper one of the two.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/769103-help-with-upgrade/#findComment-9709174
That option will only work if hes also buying a new mobo. But yes the RX is a very nice card and we have the 500 series now.
https://linustechtips.com/topic/769103-help-with-upgrade/#findComment-9709233
Where does he say that he already has a motherboard? If anything, he implies the exact opposite.
https://linustechtips.com/topic/769103-help-with-upgrade/#findComment-9709237
"Hello, im looking to upgrade my current pc build," and he only talks about upgrading CPU and GPU so Im not sure how he is implying that....
https://linustechtips.com/topic/769103-help-with-upgrade/#findComment-9709258
Well the main reason i said i didnt want amd is because i havent researched much in the new ryzen cpus, and didnt want more choices to make. Im not sure what the difference willl be in terms of gaming performance and longevity if i choose amd. As for the motherboard, im in fact upgrading it too, so if i end up with amd i could change to an amd mobo as long as the price difference isnt too high.
I had everything but the cpu and gpu sorted out but i guess i could change the other components as well.
The rest of my upgrade consists of a $90 b250m mobo, $65 evga 500b psu and $70 8gb ddr4 ram
https://linustechtips.com/topic/769103-help-with-upgrade/#findComment-9709270
Uh no... just because he mainly talks about the CPU and GPU doesn't mean he's only upgrading those two components.
"Not considering k processors because the price difference in buying a cooler and oc mobo is way too much in here."
The reason why he's not even considering a K-series CPU is because he also needs to buy a more expensive Z-series motherboard. Ergo, he doesn't have a motherboard yet.
https://linustechtips.com/topic/769103-help-with-upgrade/#findComment-9709271
I'd suggest you get a 1600+rx 480 or 580
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/769103-help-with-upgrade/#findComment-9709285
The Ryzen CPUs should honestly be your main choice. The extra threads/cores is a game-changer in itself... much more consistent frametimes in games and will be better at anything that's multithreaded. A decent B350 motherboard shouldn't cost that much as well. The fact is that nobody should really be buying i5s anymore. With i7s, it's understandable.
As for your other parts, I suggest you spend a bit more on the power supply. The Seasonic S12II 520 or the Corsair CX450M are both good choices.
https://linustechtips.com/topic/769103-help-with-upgrade/#findComment-9709317
Kk ill most likely end buying amd ryzen 5 1600 and that psu. As for the gpu, do u recommend getting the 1060 3gb($260), rx 480($303) or 1050 ti($190)?(those are the prices in my country). And as for the mobo will a msi b350m gaming pro suffice?
Thanks for the help!
https://linustechtips.com/topic/769103-help-with-upgrade/#findComment-9709378
Naturally the RX 480 4GB... but if the GTX 1060 6GB is available for around the same price, that might be better.
And yes, that motherboard is fine.
https://linustechtips.com/topic/769103-help-with-upgrade/#findComment-9709408
The gtx 1060 6gb is around 10% more expensive than the rx 480, if i cant stretch my budget ill get it.
Thanks again everyone for the help, really appreciate it
https://linustechtips.com/topic/769103-help-with-upgrade/#findComment-9709432
