1 hour ago, Storm10 said:
$800 and I'm from California
1080ti
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/768976-ryzen-1700quadro/#findComment-9708312
12 hours ago, Storm10 said:
What Quadro should I get with the Ryzen 1700?
What are you doing that needs a Quadro? CAD work? Simulations or GPU compute?
Does double precision matter to your workflow, or is single precision enough? Do the programs require CUDA or are they OpenCL based instead?
https://linustechtips.com/topic/768976-ryzen-1700quadro/#findComment-9710516
