So on an Intel motherboard that I have (Intel Spl500 socket J) board, one of the capacitors has been dented when I brought it home in a suitcase. The capacitor was a 1200 μf, 12 volt. I have bought from Radio-Shack a 1000 μf 35WVDC capacitor and a 2200 μf 35WVDC as replacements. Could I possibly use one of them as a replacement capacitor for the dented one? Also can you wrap the leads in electrical tape because sadly they are axial ones. Thanks!
(Photo from Tom's Hardware, edited my yours truly.)
https://linustechtips.com/topic/768397-capacitor-woes/
Just order the exact capacitor.
Dont take the risk and damage other components.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/768397-capacitor-woes/#findComment-9700964
both should work fine(good chance it would work without it at all)
THese are for regulation, so the exact value doesn't matter, it just smooths out the power(probably in the 12v lead)
Id try it first before replacing it as it should work just fine.
https://linustechtips.com/topic/768397-capacitor-woes/#findComment-9700971
