you basically have to make a room within your room, it is not going to be cheap or fast
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/768223-sound-proofing/#findComment-9699242
6 hours ago, Cpt.Mlem said:
Yo people :D
I'm in the middle of re-doing my office/gaming room .
I'm thinking of sound proofing the door which is 80 inches by 36 inch or , 203 cm by 91 cm.
What would be the best way of doing this and any tips on buying sound pads.
Ultimately replace the door with a solid, heavy door. The more dense the door is the lest sound will pass through it. As well, make sure the frame sticks up from the floor so that there's no air gap at the bottom. Once you have a solid, heavy door that's most likely all you can do. Putting thicker weather stripping can help a tiny bit, but ultimately the weight and density will do the most. Removing the air gap at the bottom can help as well.
Accurate.
1 hour ago, SSL said:
Sound proofing (isolation) or sound treatment (echo reduction)?
Two different goals that require different approaches.
This is correct.
39 minutes ago, RoKa said:
Two words, EGG BOXES :DD
Helps high frequency reflections only, doesn't actually do anything for sound proofing.
https://linustechtips.com/topic/768223-sound-proofing/#findComment-9700843
7 hours ago, Cpt.Mlem said:
Yo people :D
Do you own, or are you renting?
https://linustechtips.com/topic/768223-sound-proofing/#findComment-9701135
