Hello there, Can you help me out?
there seems to be an issue with my partitions, as I can't merge them back together.
It's like that because I tried to dual boot Linux mint with windows both on the same drive.
But for some reason the installer kept crashing so I tried installing it over and over, formatting the USB, redownloading the iso file and kept failing.
So I gave up and this is what I got.
I'm trying to merge the mess that I made aka the partitions back together and maybe try a new Linux distro to install and I need the extra space.
But when i tried merging them together using AOMEI Partition Assistant this error message always pops up:
"Sorry, the current operation has been canceled!
Information Code: 35
Description: Failed to open the volume. It may be locked by other programs.
What does the Information Code mean? Please refer to: http://www.disk-partition.com/help/errorcode.html "
I would like to get some help from you guys
Thank's for reading and i wish to hear your suggestions soon.
https://linustechtips.com/topic/767924-how-do-i-fix-my-partitions/
