Will I benefit from 2 GPUs?
Go to solution Solved by NoxiousOdor,
If you pair it with the 1080ti I really doubt that there would be any perceivable difference. the 1080 will be more than enough for the majority of things and with the 285 being fairly weak I don't think it would be very useful. If you had two cards that were closer to being similar there can be some benefits but I wouldn't think there would be much in this case with them being so far apart in terms of performance
Hi guys, I recently built a new system with a 1080 Ti founders edition.. I also have a GTX 285 lying around not doing anything.. will I benefit if I install it (without SLI) in my new system and run 2 GPUs? All I care for is video editing performance with after effects and premiere.
https://linustechtips.com/topic/767922-will-i-benefit-from-2-gpus/
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
For gaming no improvement unless psyux and the correct game. Many games will be slower if you use it as a physics card
For editing it will probably be slower than just the 1080ti as you may be ram limited and waiting for the slower card.
Your also limited to using a old driver.
