HELP configuring Ryzen
43 minutes ago, sgloux3470 said:The other thing to try is troubleshooting the memory sticks themselves. If only 32 GB are detected we need to figure out which sticks are working and which ones aren't being detected. First I would suggest putting each stick one at a time into slot DIMMA2 and making sure 16 GB is detected each time. Then I would try two sticks in DIMMA2 and DIMMB2. Then the same two (if they worked) in DIMMA2 and DIMMA1. Then again in DIMMB2 and B1. We want to figure out if any of the sticks are dead, or if any of the sockets are dead.
Ok so get this.
I tried every stick in slot A2 and every configuration shows 16GB except one stick, which boots but I don't get any video signal. So I would guess I have a faulty memory stick.
After that, I've tried two stick (which I knew were working based on my previous test) in slots A2 and B2 and it worked. I got signal and detected system memory was 32GB. I then tried A2 and B1 and got no video signal after boot. I thought that this was normal since the recommended 2 DIMM configuration was A2 and B2, not A2 and B1. I still tried A2 and A1 and got signal and detected system memory was 32GB.
So it seems as though I have a faulty DIMM and a faulty B1 slot on my motherboard. That seems highly improbable. Also, I could detect Memory-Z info for the B1 slot and for all DIMMs. Is that probable even with faulty DIMMs/slots ?
